Hello Guest it is October 30, 2026, 01:30:11 PM
Author Topic: MACH 3 X+_ issue  (Read 12785 times)
MACH 3 X+_ issue
« on: September 15, 2019, 04:50:12 AM »
Hi
My cnc router is x coardinate motor is moving in only one direction on both x+ and x- using arrow keys.
I am using Windows xp parallel port.
Re: MACH 3 X+_ issue
« Reply #1 on: September 15, 2019, 01:43:50 PM »
will the X axis move in both directions if you use MDI?
For example:
G1 X10 F50
G1 X0
« Reply #2 on: September 15, 2019, 10:07:27 PM »
It moves in only one direction
« Reply #3 on: September 15, 2019, 10:44:02 PM »
please confirm that it moves in only one direction when you use MDI comands to move in either direction.
If so you need to use a multimeter and measure the Direction output of your breakout board, it should be logic high
in one direction and logic low in the other direction. If that checks out then you need to look to your stepper driver.
Can you substitute the Y or Z stepper driver for the potentially faulty X axis stepper driver? It would either rule in OR
rule out the driver.
« Reply #4 on: September 16, 2019, 10:15:48 PM »
I don't understand MDI? I use the keyboard arrow keys to move the stepper motors on x+ and x-
« Reply #5 on: September 16, 2019, 11:28:17 PM »
MDI is manual data input. Have a look in the Mach operation manual.
You need to program one line at a time:
g0 x100
g0 x0
g0 x100
g0 x0
This should cause the X axis to go back and forth 100mm. It is a much more reliable and accurate method to cause an axis to move,
certainly very much more reliable than the arrow keys.
« Reply #6 on: September 16, 2019, 11:30:58 PM »
Thanks i will check
