Hello Guest it is November 13, 2026, 08:24:03 AM
Author Topic: mach3 with 5 axis machining problem  (Read 10960 times)
« on: September 01, 2019, 02:41:38 AM »
my mach3 ver. is 3.043.066 OP. is windows XP
and I got FRO% problem
Like the photo which i attached.
The letter B I have to turn down the FRO% to 30% then I got the right result and the higher FRO% the B is more twist on the end of straight line.
how could I solve this problem?
Is changing to ver. 3.043.062 helped?
Re: mach3 with 5 axis machining problem
« Reply #1 on: September 03, 2019, 12:51:46 PM »
I have tried Ver. 3.043.062
it is the same nothing changed.
any one knows why it is happened?
  •  9,377 9,377
« Reply #2 on: September 04, 2019, 12:25:52 AM »
It looks like it could be a Constant Velocity problem.
Try operating in Exact Stop mode (add G61 to the start of your Gcode) - does the problem go away ?
« Reply #3 on: September 04, 2019, 04:51:51 AM »
thank you Tweakie
Yes, Use G61 Exact stop check do solve my problem.
But G61 also make the machine work one not so smoothly.
I think I have to try to find the more solutions.
  •  9,377 9,377
« Reply #4 on: September 04, 2019, 05:00:22 AM »
You will ned to experiment to find the best settings but the solution is to reduce the Velocity setting and increase the Acceleration setting in Motor Tuning for each of the X and Y axes saving the changes.
« Reply #5 on: September 04, 2019, 09:03:02 PM »
thanks a lot
I am trying.
May be the Acceleration and Velocity of C axis and X axis and Y axis is too much different.
thanks again
