Hello Guest it is October 26, 2026, 02:52:20 PM
Author Topic: setting up 3 axis probe for chinese 6040 cnc  (Read 15569 times)
« on: August 31, 2019, 12:32:06 AM »
Want to set up 3 axis probe for chinese 6040 cncest
Want some info re  interior of my control box and where to connect the probe inputs
If anyone has a similar box any info would be highly appreciated
Offline TPS
  •  2,627 2,627
Re: setting up 3 axis probe for chinese 6040 cnc
« Reply #1 on: August 31, 2019, 01:22:47 AM »
if you are talking about Mach3, there is only one probe Input.
« Reply #2 on: August 31, 2019, 10:20:23 AM »
I am aware of that   my question is about where on the controller the actual physical connections are to be made to attach the probe
If anyone has pictures of the inside of the controller box shown and can point out to which pins/connectors the actual connections are to be made it will be highly appreciated
« Reply #3 on: August 31, 2019, 06:48:34 PM »
Without the "box" you assign an input pin in Mach for the probe. When the probe makes contact with a metal circuit it act's as a switch and the circuit is completed.
I just don't  bother with the Chinese stuff at all so can't help relative to the 6040.
You will need to read the manual if a probe connection is available.
« Reply #4 on: April 09, 2024, 11:37:01 AM »
can anyone help with limit switches on a 6040?
