Hello Guest it is October 25, 2026, 12:51:36 AM
Author Topic: Tool table issue  (Read 6175 times)
Tool table issue
« on: August 23, 2019, 03:03:27 AM »
Hi
I have some strange tool table issue which has driven me crazy. After i have set all tools in my tool table (lathe) everything works great, but after I shut down mach4 and later on open the application again the tool table has reset... example tool 1 i have X value of -50.0450 (in mm) and after i restart mach4 it suddenly becomes -50.0000 and for tool 3 I have set -35.5437 which comes -35.0000 after reset and so on.... I really don't want to write these values every time I start up mach4 and would be interested what is causing this issue?
Re: Tool table issue
« Reply #1 on: November 07, 2019, 05:33:10 AM »
I been looking this issue myself and after getting flood of responses and suggestions (I know I may have explained this issue quite badly) :) I finally managed to get it to work... I updated to latest Mach and suddenly the issue was gone... So case solved
« Last Edit: November 07, 2019, 05:35:03 AM by lerska83 »
