Mach Discussion > VB and the development of wizards
GoTo Zero script
(1/1)
first off:
Where do I edit the [GoToZero] bitmap button script? It is NOT a blinking button that is easily changed in Mach3 with the VB editor. It is linked to a Hot-Key which is scan code 2128. And what program do I use to edit it? Mach3screen? ScreenTweek? Screen4? I want to stop the Z-axis movement.
Thanks to the community for all your help. You are the best!!!!!
Tweakie.CNC:
Use one of the Screen Designers https://www.machsupport.com/downloads-updates/screensets/ (Mach3Screen perhaps) then select the desired button and change it's properties to ‘Execute VB Script’ then save the changes and close the screen designer. You will then be able to add your own script to the button using ‘Edit Button Script’ within Mach3.
first off:
Ahhhh yes that will do it. Thanks very much for your help Tweakie. Wow you have been doing this for a long time. I remember getting help from you years ago.
Regards, Russ
Navigation
[0] Message Index
Go to full version
