Hello Guest it is October 20, 2026, 03:53:30 PM
Author Topic: Mach3 RnR motion card - problem with plasma relay  (Read 48742 times)
Re: Mach3 RnR motion card - problem with plasma relay
« Reply #10 on: August 21, 2019, 04:13:12 PM »
Something like this board, but I needed more outputs.  Use the 24 volt version and it will work with the same power supply you use for the controller 24v input.  https://www.ebay.com/itm/5V-12V-24V-4-Channel-Optocoupler-High-Low-Trigger-Relay-Module-Board/183776948137?hash=item2ac9f5afa9:m:mPYQKyFRrlGUmBO9Hb0FcJg
« Reply #11 on: May 15, 2021, 05:28:37 PM »
works without problems, here are my settings ! I hope to help someone who uses 5 volt relay!  :) :)
