G-Code, CAD, and CAM > G-Code, CAD, and CAM discussions
Best Cam for 2 axis lathe?
(1/1)
Azalin:
I use Mach4. I was doing fine with Mach4' canned cycles until yesterday. Yesterday I needed to cut a complex shape but I wasn't able to do it with Mach4 canned cycles.
I normally use SolidWorks with SolidCam but I could not find a proper post processor for Mach4. So, I need switch to another Cam software for lathe.
What Cam software should I use for lathe with SolidWorks + Mach4?
Thanks in advance,
Suat
Azalin:
The lathe is a retrofitted Sieg C6. Front tool post, spindle turns only CW. Very simple machine.
Graham Waterworth:
As long as you export the profile of the part as DXF most CAM systems will do simple 2 axis lathe, look at CamBam its very low cost.
Navigation
[0] Message Index
Go to full version
