Hello Guest it is November 18, 2026, 11:28:10 AM
Author Topic: Mach4 with ESS Smoothstepper + TMC3-in-1... THC not working  (Read 7249 times)
I retrofitted a KOIKE Aronson table and am using Mach4 w/ SheetCam. Controller is an ESS SmoothStepper with TMC3-in-1. I can't get the THC to work. My Z axis is a stepper. I'm cutting designs and everything else works except the THC. TMC Screenset is reading voltage from my Hypertherm but the torch does not adjust during the cut. THC turned on, ESS Plugin set to TMC3-in-1. When I run the Z simulator, it does not go up and down 30 times, it might go up once and then make a grind noise. I'm sure it's probably something simple but I can't figure it out. HELP!!!
Re: Mach4 with ESS Smoothstepper + TMC3-in-1... THC not working
« Reply #1 on: June 25, 2019, 01:27:58 PM »
That sounds like the stepper is unable to keep up with the up/down step signals produced by the ESS.
If the machine can't follow the simulator it will not be able to follow the TMC3 either.
Is there a max velocity and/or a max acceleration setting within the THC plugin?
« Last Edit: June 25, 2019, 01:30:22 PM by joeaverage »
