Hello Guest it is October 20, 2026, 03:00:49 PM
Author Topic: Hermes Vanguard 6000 engraver  (Read 36051 times)
Re: Hermes Vanguard 6000 engraver
« Reply #10 on: March 06, 2008, 01:50:17 PM »
I have a New Hermes Vanguard 8000 and want to convert to Mach3.  It is currently running DOS directly off the PC controller card, not through an EP module.  What are the pinouts that you used on the 6000?  The 8000 is not a standard DB25, but a longer connector.  What Campbell board did you use and what cabling configuration?  I am totally new to CNC, but have strong PC and machining abilities.  My goal is to cut balsa, plywood, carbon fiber sheets and aluminum for RC cars and airplane parts.  The machine currently uses 11/64" carbide cutters or end mill.  They offer a collett spindle for $394 + $136 each for the collets to go to 1/8", 11/64" or 1/4".
« Reply #11 on: March 06, 2008, 04:31:42 PM »
Can you help me? How do we post a video here?
You can post it on You Tube then link it in your post. There is also a Mach You Tube group of videos, there is a link to it in the sticky topic at the top of this frum.
