Hello Guest it is November 13, 2026, 04:10:41 AM
Author Topic: X axis goes to Negative Values when going to RHS  (Read 11561 times)
Offline AD
  •  8 8
« on: June 11, 2019, 06:55:05 AM »
On my newly setup cnc my axes are moving fine, however for X axis my digital readout in Mach3 is showing negative values when my spindle is moving from left to right. meaning my 0 is at the most left edge of the table and instead of going to positive it goes into negative X direction and readings are negative.
My Controller is Stb5100, Motor Driver Tb6600. using laptop/usb..
I tried all combinations of different limit switch locations on LH/RH, Close/Far end along with changing Homing Directions to support that. I just cannot get a normal coordinate system: X axis to go to X+ when moving to the RHS, Y axis to go to Y+ going away from me and Z axis to go from Highest Position Zero towards Z- when going negative.
Many thanks in advance!
Offline AD
  •  8 8
Re: X axis goes to Negative Values when going to RHS
« Reply #1 on: June 11, 2019, 09:06:05 AM »
OK.. could not find a solution on this forum but on Google search - which brought me back to this forum!
In another article I lost track of, Tweakie's solution was to change X and Z status in Ports/Pins, Motor Outputs from Low Active to Hi Active (unchecked Low Active on these two axes..)
Thank you a bundle Tweakie!! I was banging my head for the last few days and could not get around this issue..Solved the problem completely..
  •  9,377 9,377
« Reply #2 on: June 11, 2019, 09:38:39 AM »
« Reply #3 on: June 11, 2019, 10:49:01 AM »
 :) Super Kitty rides again ! :)
