Hello Guest it is November 13, 2026, 01:30:55 PM
Author Topic: Mach3 on Windows 7 32 bit - Startup Screen always small  (Read 21754 times)
Re: Mach3 on Windows 7 32 bit - Startup Screen always small
« Reply #10 on: May 03, 2019, 08:28:20 AM »
I restored one of the earliest config files (April 4th) and restarted mach3.. same screen position.  Seems no matter what I do, change and save.. it ALWAYS starts half screen as in my attached picture.  I am getting to the point that something is really faulty and I might have to uninstall and reinstall the whole program.    :o
« Reply #11 on: May 03, 2019, 09:09:33 AM »
   I can easily drag open the window.. but it is very annoying.
Are you only dragging to enlarge ?
Did you try to use the RESTORE button ? then close and restart.
Russ
« Reply #12 on: May 04, 2019, 02:48:56 PM »
Yes, I have to grab the bottom of the window to open it since it now opens only half screen.  I'll try that restore and let you know if that resolves it.  Thanks.
