Hello Guest it is October 21, 2026, 04:11:09 PM
Author Topic: Mach4 Timer Script  (Read 18202 times)
Re: Mach4 Timer Script
« Reply #10 on: May 03, 2019, 05:48:52 PM »
Yup
value, rc = mc.mcCntlGetPoundVar(
      number mInst,
      number param)
« Reply #11 on: May 04, 2019, 07:10:29 AM »
Thank you for the method. They return null in a button script for me. Apparently the time variables are not implemented yet.
From poppabear.
« Reply #12 on: May 04, 2019, 02:35:21 PM »
Hi Tony,
I think that list of poppabears is out of date.
May I suggest opening the register diagnostic and pinning it to the top.
Observe the range including the timer variables. They are populated and change as time passes. This is the latest build of
Mach4 but these variables have been enacted for several years at least.
« Reply #13 on: May 05, 2019, 07:28:38 AM »
Hi Craig,
Thank you again. The Time # variables are there and are represented correctly. I must not have coded my test correctly. I will work on some timers and post my results hopefully this week.
