Hello Guest it is October 29, 2026, 01:39:50 PM
Author Topic: Mach 3 won't jog with keyboard  (Read 52216 times)
Offline RMT
  •  13 13
« on: August 31, 2007, 06:16:18 PM »
I'm been playing with the screen and now just as I get everything the way I like it, the keyboard won't jog anymore, it will still jog with the touchscreen , but not with  the keyboard.
Just to be sure I opened the editor and the arror keys move the tap around, so its not the keyboard, when checking the hot keys they are all set aswell....
Any ideas
   Frank
Re: Mach 3 won't jog with keyboard
« Reply #1 on: August 31, 2007, 06:48:52 PM »
Which version do you have? Maybe you turned off jog button?
Offline RMT
  •  13 13
« Reply #2 on: August 31, 2007, 06:55:28 PM »
No I checked that , I using Ver 2.2 and working with the simple 3 axis screen, also when I load a different screen the keyboard buttons work.
« Reply #3 on: August 31, 2007, 06:55:56 PM »
You might have turned of the Jog button, or have it in another mode, such as MPG. Hit your tab key, this brings up the MPG pendant. Check to see if you are in cont.  jog mode there. Tab will close the MPG screen as well.
Offline RMT
  •  13 13
« Reply #4 on: August 31, 2007, 07:02:34 PM »
No that ain't it either, it will jog on the screen but not with the keyboard, if it is set to mpg it won't jog on the the screen, I also tried restting the hotkeys even though it already shwed the right numbers, I will try to post the screen set You can give it a try and see if You can get it to work.
Offline RMT
  •  13 13
« Reply #5 on: August 31, 2007, 07:16:41 PM »
I thought I be able to attach the file but how do You do it?
« Reply #6 on: August 31, 2007, 07:18:07 PM »
Watch the welcome tutor, top of general Mach board.
Offline RMT
  •  13 13
« Reply #7 on: August 31, 2007, 07:32:28 PM »
That did the the trick .....thanks
Anyways see what You think
Offline RMT
  •  13 13
« Reply #8 on: August 31, 2007, 07:35:03 PM »
The one thing I like to change , on the set up page remove the stop button in the jog section and substitude for the shift button, so I be able to toggle between fast and slow jogging, but what is the oem code for the shift button?
Offline Greolt
  •  956 956
« Reply #9 on: August 31, 2007, 08:21:35 PM »
Not sure if this is your problem but when I made myself a screen set for my 12" touch screen I had
to cheat the system to get jogging working.
I did not want a button to turn jog on/off taking up precious screen real estate.
I never want to not be able to keyboard jog.
It's a tight squeeze on 12" when you want large  buttons for fat fingers.  ;D
However I soon found that unless you have a jog on/off button on any particular page
then the keyboard jog won't work while using that page.
So what I did was make a jog on/off button that was 1 pixel by 1 pixel and hide it at
the very top left of screen and set it to "displays on all screens"
Now I can keyboard jog on any page but not have a useless button hogging screen space.
Greg
