Hello Guest it is November 13, 2026, 12:14:14 PM
Author Topic: Help wiring limit switch to servo tec board  (Read 47126 times)
Offline reuelt
  •  520 520
Re: Help wiring limit switch to servo tec board
« Reply #10 on: May 09, 2019, 11:56:09 PM »
When I tried to wire two switches I can’t get them both to work on the same input, only one.  I tried every combo in all the posts I found.  How should pnp’s be wired so each can trip independently?
You may need have an "EXCLUSIVE-OR" IC on a PCB.
Or buy EX-OR Module to test first (see attached)
"the gift of God is eternal life through Jesus Christ our Lord"
Offline TPS
  •  2,627 2,627
« Reply #11 on: May 10, 2019, 01:36:09 AM »
normaly your Limit Switches have three wires:
Brown -> 24v
blue -> 0V
black -> Output
so if you want two (NC) Switches in series you have to wire:
Switch 1
Brown -> 24v
blue -> 0V
black -> to Brown of Switch 1
Switch 2
Brown -> from black of Switch 1
blue -> 0V
black -> to input
Offline reuelt
  •  520 520
« Reply #12 on: May 10, 2019, 08:41:49 AM »
Brown -> 24v
blue -> 0V
black -> Output
Switch 1
Brown -> 24v
blue -> 0V
Switch 2
blue -> 0V
black -> to input
He has an indu
Brown -> 24v
blue -> 0V
black -> Output
Switch 1
Brown -> 24v
blue -> 0V
Switch 2
blue -> 0V
black -> to input
He is using semiconductor (non-contact) sensors and not mechanical switches.
I do not think you can connect those electronic PNP sensors in series and in NC mode. I may be wrong.
