Hello Guest it is November 13, 2026, 06:43:58 PM
Author Topic: Quick conversion of code from linear to angular movement  (Read 42612 times)
Re: Quick conversion of code from linear to angular movement
« Reply #20 on: August 24, 2007, 10:57:42 PM »
Good for you Alex.  :)
Yes Whacko, I see your avatar. The first time I saw it, was out of the corner of my eye. Thought, what the h*&(. LOL, funny.
« Reply #21 on: October 06, 2007, 04:43:57 PM »
You don't need a switch, Mach has a "swapaxis" software function like I said in the beginning,
   I try to  engrave text  on a  tube too . Can you give more information about swapaxis ? Can Mach3  convert  Y linear movements into angular ?
Murat.
« Reply #22 on: October 07, 2007, 06:26:09 AM »
Not to my knowledge.  I use a small conversion program from the MaxNC software I have from my old Maxnc mill.
« Reply #23 on: October 07, 2007, 06:06:40 PM »
I have created a relief and I would like to engrave it on outer edge of ring like seen below. Can you please convert this g-code to rotary g-code? I have tried to replace all Y letter with A but my rotary head always turns in Cw so it deforms the relief. I guess (-) is needed  before the A value to ensure CCW rotation.
Murat..
