Hello Guest it is November 23, 2026, 02:09:05 PM
Author Topic: Remote Input to Start and output when complete  (Read 24157 times)
Offline reuelt
  •  520 520
Re: Remote Input to Start and output when complete
« Reply #10 on: April 27, 2019, 12:47:18 AM »
There are many ways
here is one possible way:-
You can install one relay to one of OUTPUT#1 to OUTPUT#20 in ports and pins.
Then write a custom M### code to turn on the relay and another to turn off the relay
( using a free macro name from  M791 - M798)
say it is M797 turns on relay
and M798 turns off relay
Then,
you can add M998
before you end your program with M30
and add M997 when you start the program.
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #11 on: April 29, 2019, 07:10:24 AM »
Thanks to everyone. This site is pretty awesome. Trying to work on this and design a Vision Camera system at the same time and its a little confusing when you can not dedicate all of your time. Actually, this is a lot more interesting and fun.
All of the info has been very helpful.  not very up on VB and doing custom macro programs.  is there any reading material or some type of Macro for dummy book related to Gcode type programming?   Thanks
Would it be too much to ask if you wrote an example of the above macro? Not asking to actually do it for me, but a sample similar would be very helpful. Sample programs, schematics etc. like what is on here and a couple of other great Forums I use such as Plc.net and Mr.Plc are worth a lot more and very helpful.
« Last Edit: April 29, 2019, 07:12:57 AM by irondesk40 »
Offline TPS
  •  2,627 2,627
« Reply #12 on: April 29, 2019, 01:16:44 PM »
code to turn a Output ON
Code: [Select]
Sub Main()
 ActivateSignal(Output1)
End Sub
code to turn a Output OFF
Code: [Select]
Sub Main()
 DeactivateSignal(Output1)
End Sub
feel free to read any manual
« Last Edit: April 30, 2019, 02:51:51 AM by Tweakie.CNC »
