Hello Guest it is October 22, 2026, 04:19:38 PM
Author Topic: chinese cnc probing macros?  (Read 88270 times)
Offline TPS
  •  2,627 2,627
Re: chinese cnc probing macros?
« Reply #20 on: April 25, 2019, 01:51:16 AM »
all those "probing" macros will work, no question,
but the Point is the accuracy you whant to have?
but this is a complete other discussion and offtopic here.
« Reply #21 on: April 25, 2019, 05:45:51 AM »
'Note that there are also, FRENCH and ITALIAN probing macros (posted in this forum) that DO NOT use those legacy setvar() and getvar() functions.
GetVAR() is not a "legacy" function. It's the proper and only accurate way to read the trip point. And the majority of chinese controllers do not support it's use.
Offline TPS
  •  2,627 2,627
« Reply #22 on: April 25, 2019, 06:06:16 AM »
thats what i tryed to say. ;)
  •  9,374 9,374
« Reply #23 on: April 25, 2019, 06:28:54 AM »
It is perhaps as Craig has been saying all along, in many other postings - if you want accurate and reliable machining / probing / etc. then forget the cheap Chinese controllers.
« Reply #24 on: April 25, 2019, 04:12:10 PM »
i will leave the screensets for a while,,,,,,,with my normal setup i have added the big tex m6 strart macro,,,,at least now i have the spindle move to the fixed plate location where i can change the tool and use the auto toll zero function,,,then continue with the cut. when i get more time i will sort a new controller,,, has anyone tried the " AXBB-E ethernet motion controller and breakout board combined controller " from the company behind of uccnc .
Offline reuelt
  •  520 520
« Reply #25 on: April 26, 2019, 01:53:17 AM »
See attached cut from "Mach3 V3.x Macro Programmers Reference.pdf" by NFS.
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #26 on: April 26, 2019, 06:19:42 AM »
EVERY function is in the "legacy" list.
« Reply #27 on: April 26, 2019, 06:20:32 AM »
I have one, but have not tried it with Mach3. I bought it for use with UCCNC.
