Hello Guest it is October 02, 2026, 12:49:59 PM
Author Topic: Mach3: Expose APIs from Mach4.Document  (Read 22518 times)
Re: Mach3: Expose APIs from Mach4.Document
« Reply #10 on: April 10, 2019, 11:29:39 AM »
It's been many years since I developed my Mach3 COM wrapper.  I was using Delphi which is object pascal.
https://www.machsupport.com/forum/index.php?topic=32144.0
 I have attached another pascal file (renamed .txt for upload).  I think you could rewrite it to C++ fairly easily.
HTH
RT
« Reply #11 on: April 10, 2019, 08:47:07 PM »
Hi RT
Thanks for the example.  I give up looking for official Mach3 COM programming manual,
but your example is more than enough !! That's big help.
Thanks a lot
KC
HTH
RT
Die hard vi lover ;-)
Offline TPS
  •  2,627 2,627
« Reply #12 on: April 11, 2019, 01:53:47 PM »
i think CMyScriptObject.h file from machremote example is also a good reference
« Reply #13 on: August 17, 2020, 06:55:18 PM »
I can run MachRemote now, but I don't know which APIs or commands I can use ?? From source code of MachRemote, I can find
hi kccheng, did you ever find a list of usable functions?
i'm creating a python connector, I've got the following functions to work. I cant get doOEMbutton or GetOEMLed to work.
LoadGCodeFile('C:\Mach3\GCode\cross.tap')
cyclestart()
closefile()
shutdown()
SetFRO(100) #feedrate override, send percent
