Hello Guest it is October 23, 2026, 12:08:27 AM
Author Topic: hold all axis also on jog  (Read 24612 times)
Offline smurph
  •  1,575 1,575
Re: hold all axis also on jog
« Reply #20 on: April 02, 2019, 08:40:59 AM »
when checking return codes, is it preferred to use the actual error definition versus the number?
Yes.  The underlying number could change, although not very likely.  However, the possibility exists, so use the constant whenever possible.  You just can't go wrong using constants.
Steve
Offline jbuehn
  •  101 101
« Reply #21 on: April 02, 2019, 10:19:15 AM »
Thanks!
Offline smurph
  •  1,575 1,575
« Reply #22 on: April 02, 2019, 05:50:50 PM »
To expand further with some more best practices, break the code up into functional elements.  The OP's original question was about inhibiting motion and jogs.  So let's make the code a bit more modular.
Code: [Select]
function InhibitMotion(inhibit)
    local inst = mc.mcGetInstance('InhibitMotion()')
    local rc, hSigInhitbitMotion
    hSigInhitbitMotion, rc = mc.mcSignalGetHandle(inst, mc.ISIG_MOTION_INHIBIT)
    if (rc ~= mc.MERROR_NOERROR) then -- check retun codes!
        mc.mcCntlMacroAlarm(inst, 600, 'Could not retrieve ISIG_MOTION_INHIBIT signal handle!')
return
end
if (inhibit) then
rc = mc.mcSignalSetState(hSigInhitbitMotion, 1) -- raise the mc.ISIG_MOTION_INHIBIT signal
mc.mcCntlMacroAlarm(inst, 602, 'Could not set ISIG_MOTION_INHIBIT signal state to 1!')
return
end
else
rc = mc.mcSignalSetState(hSigInhitbitMotion, 0) -- lower the mc.ISIG_MOTION_INHIBIT signal
mc.mcCntlMacroAlarm(inst, 604, 'Could not set ISIG_MOTION_INHIBIT signal state to 0!')
return
end
    end
end
function InhibitJog(inhibit)
    local rc, hSigInhitbitJog
    hSigInhitbitJog, rc = mc.mcSignalGetHandle(inst, mc.ISIG_JOG_INHIBIT)
        mc.mcCntlMacroAlarm(inst, 601, 'Could not retrieve ISIG_JOG_INHIBIT signal handle!')
return
end
if (inhibit) then
rc = mc.mcSignalSetState(hSigInhitbitJog, 1) -- raise the mc.ISIG_JOG_INHIBIT signal
mc.mcCntlMacroAlarm(inst, 603, 'Could not set ISIG_JOG_INHIBIT signal state to 1!')
return
end
else
rc = mc.mcSignalSetState(hSigInhitbitJog, 0) -- lower the mc.ISIG_JOG_INHIBIT signal
mc.mcCntlMacroAlarm(inst, 605, 'Could not set ISIG_JOG_INHIBIT signal state to 0!')
return
end
    end
end
function InhibitMotionAndJog(inhibit)
InhibitJog(inhibit)
end
There are three functions in that code snippet; InhibitMotion(), InhibitJog(), and InhibitMotionAndJog().  Each takes one parameter called inhibit.  InhibitMotionAndJog() simply calls InhibitMotion() and InhibitJog().  Breaking the functions up like this give you the option of using these function in other piece of code, if needed.  What if you simply wanted to inhibit jogs?  Well...  there is a function for that.  :)
Now that we have them inhibit functions, we can call them a variety of ways.  Through the PLC script, through the signal script, or the siglib in the screen load script.
Example for the PLC script checking if the machine is homed:
Code: [Select]
-- the following functions should reside in the screen load script.
function CheckHomed()
    local inst = mc.mcGetInstance('CheckHomed()')
    local homedX, homedY, homedZ, homed, rc, hSigInhitbitMotion, inhibitMotion
    homedX, rc = mc.mcAxisIsHomed(inst, mc.X_AXIS)
        mc.mcCntlMacroAlarm(inst, 5000, 'Could not retrieve X axis homed condition!')
return
end
    homedY, rc = mc.mcAxisIsHomed(inst, mc.Y_AXIS)
        mc.mcCntlMacroAlarm(inst, 5001, 'Could not retrieve Y axis homed condition!')
return
end
    homedZ, rc = mc.mcAxisIsHomed(inst, mc.Z_AXIS)
        mc.mcCntlMacroAlarm(inst, 5002, 'Could not retrieve Z axis homed condition!')
return
end
        mc.mcCntlMacroAlarm(inst, 5003, 'Could not retrieve ISIG_MOTION_INHIBIT signal handle!')
return
end
    inhibitMotion, rc = mc.mcSignalGetState(hSigInhitbitMotion)
        mc.mcCntlMacroAlarm(inst, 5005, 'Could not retrieve ISIG_MOTION_INHIBIT signal state!')
return
end
homed = homedX and homedY and homedZ
if ((homed == 0) and (inhibitMotion == 0)) then
InhibitMotionAndJog(true)
elseif ((homed == 1) and (inhibitMotion == 1)) then
InhibitMotionAndJog(false)
    end
end
-- and a line in the PLC script like:
CheckHomed()
Example for the siglib using inputs 1, 2 and 3.
Code: [Select]
-- Signal Library
SigLib = {
[mc.OSIG_MACHINE_ENABLED] = function (state)
machEnabled = state;
    ButtonEnable()
end,
[mc.ISIG_INPUT0] = function (state)
end,
[mc.ISIG_INPUT1] = function (state)
if (state == 1) then
InhibitMotion(true)
else
InhibitMotion(false)
end
end,
[mc.ISIG_INPUT2] = function (state)
InhibitJog(true)
else
InhibitJog(false)
end
end,
[mc.ISIG_INPUT3] = function (state)
else
end
end
Steve
Offline jbuehn
  •  101 101
« Reply #23 on: April 02, 2019, 06:31:37 PM »
That's great info Steve. I've been learning (sometimes the hard way) the advantages of using return codes! It definitely makes debugging / logging easier.
« Reply #24 on: April 02, 2019, 09:14:52 PM »
Hi Smurph,
Code: [Select]
It is the first time I have seen, that I recall, a string as an argument passed to the mcGetInstance API. Is there a particular
reason you have done it?
Offline smurph
  •  1,575 1,575
« Reply #25 on: April 02, 2019, 09:48:17 PM »
 That string is a marker that is associated with the instance handle.  It is used with API function call tracing in the Mach Log.  It makes it so that you can see what called the API function.
Steve
