Hello Guest it is October 15, 2026, 02:10:32 PM
Author Topic: RefAllHome - then back off.  (Read 16120 times)
Re: RefAllHome - then back off.
« Reply #10 on: March 24, 2019, 11:52:31 PM »
is there a doc that describes all the "mc." functions available?
Yes...is there what!  Its called Mach4CoreAPI.chm and it found in the help documents which opens with the <Help Docs>
button or found in the Docs folder in Mach4Hobby directory.
There are hundreds of functions....enjoy.
« Reply #11 on: March 25, 2019, 07:09:59 AM »
API Document in the Docs folder in your Mach4 folder.
Chad Byrd
« Reply #12 on: March 25, 2019, 07:28:49 AM »
File name:  Mach4CoreAPI.chm
Chad Byrd
« Reply #13 on: March 25, 2019, 08:53:23 AM »
Would you be kind enough to attach that file?
I'm at work today and at a conference all week, I'd like to convert and print it.
If you can't that's fine I'll just install the demo on a VM here and pull it that way.
« Reply #14 on: March 25, 2019, 03:05:19 PM »
Not sure that you can convert and print it. It is a .chm file and is intended to be opened by a Windows Help function.
Aside from anything else the printout would be several hundred pages. Download and read it, then work out which
bits you want to print....
Offline thosj
  •  542 542
« Reply #15 on: March 25, 2019, 03:42:00 PM »
Can do easy....but still a lot of paper!!
https://www.print-driver.com/how-to/convert-chm-to-pdf
Tom
Tom
« Reply #16 on: March 25, 2019, 06:02:13 PM »
I've done it before - it's poorly paginated to be sure but its a simple conversion.
