Hello Guest it is October 22, 2026, 03:36:39 PM
Author Topic: Limit switches and PWM for laser  (Read 31957 times)
Offline MN300
  •  306 306
Re: Limit switches and PWM for laser
« Reply #10 on: March 23, 2019, 12:56:50 PM »
It would help to know if your laser is looking for an analog signal or PWM signal (digital). As an example, Opt Laser’s PLH3D will work with either.
Offline reuelt
  •  520 520
« Reply #11 on: March 24, 2019, 01:06:07 AM »
I think he already said PMW. It is easy to get an analog from PMW pin. His problem is his BOB has only an analogue to be used for Spindle.
In the USB system, you cannot just add another BOB (unlike parallel port system) - it won't work. You have to replace the whole motion control with a more expensive one + 2 parallel BOBs. Then you can have more than 1 PMW or analogue.
That's why I will never buy a cheap USB motion controller.
« Last Edit: March 24, 2019, 01:08:04 AM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #12 on: March 24, 2019, 02:31:21 PM »
MN300, Here's the driver module.  I thought getting a usb vs parallel connection, I would be getting something easier to work with on the VFD inverter.  My bad.
xlr8sion
« Last Edit: March 24, 2019, 02:49:06 PM by xlr8sion »
Offline MN300
  •  306 306
« Reply #13 on: March 24, 2019, 05:25:02 PM »
xlr8sion,
Your laser board appears to be a SW-LD73 V1.1 which uses PWM to control the output.
reuelt asked earlier if you are using all 4 axes. If one axis is free it can be used to provide PWM for the laser. If none are free and the laser is a must then you will need a different BOB board.
The documentation for the BSMCE04V USB board is questionable. The diagram seems to be from an Aliexpress site selling a controller and drive package. The PDF file says it's the Mach3 USB Motion Card STB4100 V2.1 Installation manual.
There is no explanation of the uses of AVI+ and AVI- terminals. In the diagram AVI- connects to the Inverter GND terminal, this would say it's the same as COM. If so, why isn't it just labeled COM? Although it's normally a high end feature maybe the analog output is opto-isolated. Use your ohmmeter to measure from the COM terminal to AVI+ and to AVI-. If the readings are infinite then the output is isolated.
Since this board is what you have let's make our best attempt to make it work.
First you can follow instructions and do the setup to get the axes moving. Leave the spindle and laser wiring for later. The switches in the diagram are all normally open. The home switches are connected in parallel. You will have to make sure none are on at the start of the homing sequence. If one is actuated at the start the controller would have no way to determine which it is and which axis to move to clear it. Actually I suppose if just the Z switch is on and the Z axis is first the homing will work.
Once you have things moving you can go on to the spindle and the laser.
MN300
Offline reuelt
  •  520 520
« Reply #14 on: March 24, 2019, 11:27:40 PM »
"In the diagram AVI- connects to the Inverter GND terminal, this would say it's the same as COM. If so, why isn't it just labeled COM? "
Analogue ground for Inverter is different from COM which is the digital ground.
If the BOB provides 0-10V analogue rather than PWM, then there must be a separate ANALOGUE Ground which must not be connected to com.
I have a Nowforever VFD inverter and I MUST connect 4 wires to my BOB when others who use PWM only need 3 wires.
(The Manual was a translated manual from a Russian manual by someone in CNCZONE because no one could find the BSMCE04V manual anywhere . In Russia, the same board has a different model number.)
« Reply #15 on: March 25, 2019, 09:24:06 AM »
Reuelt, MN300,  thanks for all the time and effort that you have put into my questions.  Still working on the project.  And yes I do have the 4th axis that I can work with.  I still need to hook up the limit switches, have some cannon connectors on order for the backside of the VFD box. Going with four connectors in case I renew the BOB.  Do I need to use shielded cable for wire run?  Connecting the switches in parallel as needed by the BOB, would disable the functions in MACH3 diagnostics readout.  Just the same, as long as keeps me from jamming the table.
xlr8sion -- may change to (snail), for my CNC experience
Offline MN300
  •  306 306
« Reply #16 on: March 25, 2019, 09:41:34 AM »
Yes, the equipment you have is limited but usable.
Could you get away without using shielded cable? - Maybe, but you don't want to find out the hard way. Run a separate shielded pair to each switch, someday you will probably invest in a better BOB board with more inputs.
I suggest that you start up the system is stages, First get the axes moving, then the spindle.
I can't find a manual for the hardware side of your PRT-e1500w inverter. Did you get a paper copy? A picture of its terminal strip(s) would be a help if nothing else is available.
Offline MN300
  •  306 306
« Reply #17 on: March 25, 2019, 10:13:01 AM »
It occurred to me that your system has only a software E-Stop. On an industrial machine the E-Stop hardware stops motion independent of the main control. Better BOB boards have a dedicated E-Stop input that will stop the steppers and the spindle immediately. You have to decide how much risk there is of damage to the machine and of personal injury.
The inverter wiring can be tied to the E-Stop, this probably will involve adding a relay.
Info on your stepper driver boards will show if they have an enable input that can be shutdown by an E-Stop.
Offline reuelt
  •  520 520
« Reply #18 on: March 25, 2019, 04:25:49 PM »
If you have the 4th axis, there is another way to use the laser even without changing your BOB. You can have a micro-switch with bended long lever mounted on the spindle mount so that when the z-axis is lowered and the micro-switch is switched-on by touching the material, then the laser in turned ON.
You can get an external PWM power supply to control the light in volume.
Some have done it that way and uploaded videos on YOUTUBE
It is better to use shielded cable for the limit switches but even non-shielded wire is OK - IF you use "normally closed" limit switch system. Because the two limit switches connected in series for each axis and are normally closed (current is already flowing), it is less affected by EMI noise.
Even with limit switches installed, you should set up soft limits to trigger about 0.1" BEFORE the far end limit switches go open.
Take a clear picture of your BOB (as I requested before) and I can help you with limit switches step by step.
« Reply #19 on: March 25, 2019, 06:48:35 PM »
there is another way...its a bit of a cheat but it works.
If you have the 4th axis step and direction pins still available use the direction pin to turn the laser on or off
and use a frequency-voltage converter IC on the step pin to generate an analogue voltage.
There are some significant limitations with this idea.
The main one is that if you want a low laser output power then the step frequency of the 4th axis will necessarily be
low, so low in fact that it may represent the limiting axis of a coordinated move (the  X and Y axes go slow so as to be
coordinated with the 4th axis). Conversely if you limit the 4th axis step frequency and thereby establish a maximum
analogue voltage then the 4th axis will again be the limiting axis.
with respect to coordinated moves.
