Hello Guest it is November 20, 2026, 05:38:37 AM
Poll
Do you use a Charge Pump with Mach (either parallel port OR external)?
Yes
3 (27.3%)
No
8 (72.7%)
'Dont be so bloody personal' LOL
0 (0%)
Total Members Voted: 11
Author Topic: Do you use a Charge Pump?  (Read 21898 times)
  •  9,378 9,378
Re: Do you use a Charge Pump?
« Reply #10 on: May 18, 2019, 09:45:08 AM »
A related question is whether people have an E-Stop circuit that breaks power to motors and lasers rather than just the control wiring?
I have both.
The software polled EStop and a contactor controlled AllStop which disconnects power to everything except the PC, associated motion controller and screen. Although it is there and always available for an emergency AllStop has not been used in years.
« Reply #11 on: May 18, 2019, 10:03:36 AM »
If you're using the Charge Pump, it ideally would tie in to the Estop loop, so that either the Charge Pump or an Estop button will kill power to everything.
  •  9,378 9,378
« Reply #12 on: May 18, 2019, 10:09:35 AM »
The difference between EStop and AllStop can perhaps be likened to 'turning off the switch' and 'pulling the plug'.
