Hello Guest it is October 22, 2026, 08:01:10 PM
Author Topic: Jumpy arcs and curves in Mach4  (Read 13886 times)
Re: Jumpy arcs and curves in Mach4
« Reply #10 on: March 18, 2019, 02:11:53 PM »
FOUND IT!!!
OK, for whatever reason, CV was NOT activated.  We had to add a G64 to the front of the program to activate it.
After that, smooth curves!
I have since added the G64 to the initialization line in the Mach setup screen.  I thought checking the Constant Velocity button would do this?
We are still monitoring this, because randomly, CV has turned itself off again.
We can manually add the G64 to the program when we see this and all is well.
Not sure what happened to turn it off though...
Offline reuelt
  •  520 520
« Reply #11 on: March 19, 2019, 10:46:30 PM »
You might need to increase the "Lookahead" lines from the default of 200.
"the gift of God is eternal life through Jesus Christ our Lord"
