Hello Guest it is November 23, 2026, 02:21:53 AM
Author Topic: unable to ref all home  (Read 7511 times)
« on: March 12, 2019, 02:30:38 PM »
Hey looking for some help here and think its pretty simple fix, i hope!!!
getting a message" requested home axis home switch is active please fix then home" how do i fix?
when in ref all home my dros go to zero my machine stays put. Working on day 2 of frustration.Please help
Offline reuelt
  •  520 520
Re: unable to ref all home
« Reply #1 on: March 12, 2019, 04:20:22 PM »
Power off the machine (Not the PC), manually turn (crank) the stepper motor so that no switch is active.
Turn machine on
Click on [reset] in MACH3 and try ref all home again.
If it works this time, you must do two things
1. Set your "debounce" to 50 or more - in top right hand corner of settings | general settings page (see attached)
2. implement"soft limits" which is from 0 to say just 0.1 inch before the limit switch at the other end of each axis. Then always leave soft limits on.
« Last Edit: March 12, 2019, 04:22:54 PM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
