Hello Guest it is November 23, 2026, 03:12:29 PM
Author Topic: Problem with generated rotary job toolpath.  (Read 7916 times)
« on: March 04, 2019, 10:07:42 PM »
I refer to my topic in Vectric forum and need help in order to find out why my generated g-codes gives a different machining toolpath than it was shown in the v-carve softvare.
http://forum.vectric.com/viewtopic.php?f=2&t=31620&p=228998#p228998
Are there anybody here who can help me with this issue?
Offline olf20
  •  325 325
Re: Problem with generated rotary job toolpath.
« Reply #1 on: March 05, 2019, 06:34:48 AM »
I have done some rotary stuff several years ago.
I can not help you much, but if it was me I would
start with a very simple like turning square to round
by some length.
Then go to something a little more complex like cutting
your name in the turned piece.
That way you can maybe identify what the problem is.
I think I had to modify Vetric's post processor when
I done mine.
Maybe Ger with chime in and give you some help.
He seems to be quite knowledgeable on this.
olf20 / Bob
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: March 06, 2019, 07:33:14 PM »
Are you sure the a axis is rotating in the right direction and at the correct distance.
To check the rotation place a hex head bolt or a piece of hex bar end in the chuck and set a flat square with a clock or a square block.
Then enter and run this program :-
G92 A0
G91
G00 A60.
M30
The A axis should roll the top of the chuck toward you for 60 degrees and the next flat should be square to your original flat.
