Hello Guest it is November 26, 2026, 04:52:41 AM
Author Topic: write to a register  (Read 11722 times)
Offline Bill_O
  •  616 616
write to a register
« on: February 27, 2019, 09:08:07 AM »
Ok.
Yesterday I had a script that would read a register then set another register.
I realized that is not what I needed and deleted it.
Now I need to read a dro then write the value to a register.
Of course it is not working so I am once again asking for help.
The script editor is telling me the problem is the last line.
Here is the code:
--read value from dro
local EncScale = scr.GetProperty('droEncScale', 'Value')
--set register handle
local hreg = mc.mcRegGetHandle(inst, 'iRegs0/EncScale')
--set register
local mc.mcRegSetValue(hreg,'EncScale')
BTW how to do this will be written down this time.
Bill
Re: write to a register
« Reply #1 on: February 27, 2019, 09:46:21 AM »
did you test the value in EncScale that returned?  Was it a double?
Did you test the value returned to hReg, rc= mc.mcRegGetHandle(inst, 'iRegs0/EncScale')?
What value was returned by rc = mc.mcRegSetValue(hreg,'EncScale')
« Reply #2 on: February 27, 2019, 11:49:50 AM »
you have coded:
Code: [Select]
So you have attempted to put in a register which is expecting a value (numeric) with a string "EncScale".
I have already posted:
Note all this and more is covered in the Mach4 Scripting Manual chapter 4, in Mach4Hobby/Docs folder.
Have you read it?
Offline Bill_O
  •  616 616
« Reply #3 on: February 27, 2019, 12:56:51 PM »
craig,
yes i have read it.
i thought the 'EncScale' was a variable
the largest problem i am having with this script is the line "local hreg = mc.mcRegGetHandle(inst, 'iRegs0/EncScale')"
this is the exact same line i have in another script "local hreg = mc.mcRegGetHandle(inst, 'Encoder_0')"
the second works the first does not
both are registers
bill
« Reply #4 on: February 27, 2019, 01:37:15 PM »
that was the purpose that I explicitly pictured and posted  a shot of the Regfile Diagnostic panel so that
you could see the naming tree.
If you wish or need to address a register for the purposes of getting its handle use the diagnostic panel.
« Reply #5 on: February 27, 2019, 02:46:41 PM »
Sometimes it is pretty easy to get lost in coding and miss details.
EnScale is a variable but when you tried to set the 'iRegs0/EncScale' register you passed the string 'EncScale' not the variable EncScale
local mc.mcRegSetValue(hreg,'EncScale')<----the string
local mc.mcRegSetValue(hreg,EncScale) <----the variable value
which for safety sake:
local mc.mcRegSetValue(hreg,asnumber(EncScale'))
Offline Bill_O
  •  616 616
« Reply #6 on: February 28, 2019, 07:12:29 AM »
rhtuttle,
thanks
i knew it was something simple in how i typed it but did not know what.
thanks again,
Bill
« Reply #7 on: February 28, 2019, 07:44:03 AM »
Did you mean
local mc.mcRegSetValue(hreg,tonumber(EncScale))
« Reply #8 on: February 28, 2019, 09:15:11 AM »
Been working on hardware lately and not coding LUA.  Thanks for catching that.
« Reply #9 on: February 28, 2019, 03:36:55 PM »
No problem.
