Hello Guest it is September 05, 2026, 03:51:46 PM
Author Topic: Mach 3 Turn - X axis dives to zero after tool change...  (Read 7395 times)
« on: February 26, 2019, 10:46:54 AM »
Good morning all,
I have been working on my lathe trying to clean some of the configuration and screens up and I broke something somewhere.
Here is roughly the program I am running...
G90 G95 G97
T0101
M3 S1000 (X dives to zero - Centerline of part)
G00 Z.1
X1.0
G01 Z-1.0 F.005
G00 X1.1
G91 G28 X0
G28 Z0
G90 G95 G97
T0202
M3 S1000 (X dives to zero - centerline of part)
G00 Z.1
X1.0
G01 Z-1.0 F.005
G00 X1.1
G91 G28 X0
G28 Z0
M05
M30
The lines are commented with the unexpected X move.  Aside from that, the program runs as expected and positions correctly.
Any idea what I screwed up to cause that?
Thanks in advance!
Chris D
Re: Mach 3 Turn - X axis dives to zero after tool change...
« Reply #1 on: February 28, 2019, 02:22:20 AM »
Most likely the M6End.m1s macro. It is not normally used in Turn so open it with the editor and remove the text or comment the text out.
« Reply #2 on: February 28, 2019, 05:16:10 AM »
Thanks for the info, I will look into that.
Chris D
