Hello Guest it is October 23, 2026, 06:16:53 PM
Author Topic: Laser 15W setup with 4axis USB board  (Read 35787 times)
« on: February 21, 2019, 02:54:55 AM »
Hi, friends
Need help!
I use this board
 https://cnc1.lv/en/cnc-controllers/273-usb-mach3-100khz-breakout-board-4-axis.html
with my CNC 6040!!
I purchase this  laser
https://www.ebay.com/itm/15W-Laser-Head-Engraving-Module-w-TTL-450nm-Blu-ray-Wood-Marking-Cutting-Tool-o/183115085067?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
How to easy connect laser to this board (Mach3) using only z settings or spindle settings to turn it on or off... (I do not want to make some big modification)?!
Is it possible to use TTL or PWM with this board?
For graving I use Vectric!
lp, from Croatia
  •  9,374 9,374
Re: Laser 15W setup with 4axis USB board
« Reply #1 on: February 21, 2019, 04:01:18 AM »
Mach3 has a dedicated command set (M11P#/M10P# ) intended for laser switching and I have described its use here; http://hobbycncart.com/publ/cikkek/mach3_temaju_cikkek/switching_a_laser_under_mach_control/8-1-0-29
If you want to control laser output power then this post may be of interest; https://www.machsupport.com/forum/index.php?topic=12444.msg265104#msg265104
Hope this helps.
« Reply #2 on: February 21, 2019, 04:40:10 AM »
that USB controller board is not a good one, very little information about them, no one seems to know who
makes them and very few people have ever got them to work properly. It certainly doesn't support G31
probing and the chances it supports laser operations is even slimmer.
http://www.machsupport.com/forum/index.php/topic,38089.0.html
Offline ZASto
  •  434 434
« Reply #3 on: February 21, 2019, 04:49:48 AM »
I'm not willing to dig the 'net for manual for this chineese board, but, if you find that there's output that can give you pwmwith varyuing dyty cycle, you should be able to controll your laser.
« Last Edit: July 22, 2019, 05:40:37 AM by Tweakie.CNC »
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
« Reply #4 on: February 22, 2019, 04:10:42 PM »
Hi, I cheat my CNC (see video)  :)
https://youtu.be/3wBpa7--aBM
For now I'll use push switch with z axe! It's working ok for now :)
Is there a way to use direction pin on my z axis for controling on/off my laser?!
lp, chris
Offline TPS
  •  2,627 2,627
« Reply #5 on: February 23, 2019, 01:45:35 AM »
as Tweakie mentioned , get familiar with the M10P# and M11P# functionality.
« Reply #6 on: February 26, 2019, 04:04:05 AM »
using only z settings or spindle settings to turn it on or off.:)
« Reply #7 on: May 10, 2022, 09:08:34 AM »
Would appreciate some help in connecting my laser to the Bitsensor board. Attached is my connection. I can switch the laser on/off and adjust power, but it is not strong enough to make engravings. Adjusting the power also seems to work in reverse, when i increase power in Mach 3 software the power of the lase seems to decrease...
