Third party software and hardware support forums. > PoKeys
Problem with Home/Limit Switches
(1/1)
Bullwy:
Good day, I'm using Pokeys57cnc. However, for some unknown reason, I am not able to have mach3 recognizing the switches. I have connected on pin 18 on the axis switch connecteor for the x axis the switch, so that when it is hit, low potential is on. On mach 3 I had selected as home ref switch pin 18, didnt work (showed no reaction to the chaning of the potential). I then switched to external dedicated, didn't work either. I then tested the additional limit swichtes connections, same there on pin 11. I'm sure I'm missing out on something, but I cannot figure out what it is. I followed the manuals of pokeys, to no avail so far. Any guesses?
Bullwy:
Solved. Had to reset the PoKeys controller.
Navigation
[0] Message Index
Go to full version
