Hello Guest it is November 14, 2026, 02:17:30 AM
Author Topic: DQ542MA  (Read 33715 times)
Offline TPS
  •  2,627 2,627
Re: DQ542MA
« Reply #10 on: February 11, 2019, 05:25:35 AM »
have you tryed to connect the y-Controller to the x Step/dir signal's?
Re: DQ542MA
« Reply #11 on: February 11, 2019, 05:45:21 AM »
It does exactly the same   :-\  :'(
Offline TPS
  •  2,627 2,627
Re: DQ542MA
« Reply #12 on: February 11, 2019, 05:47:34 AM »
so the working y-axis Controller is also not working if it is connected to the x-axis signals?
Re: DQ542MA
« Reply #13 on: February 11, 2019, 06:04:54 AM »
If I unplug the connection from the Y axcis and put it into the XAxis motor. The motor works
Re: DQ542MA
« Reply #14 on: February 11, 2019, 11:36:33 AM »
Doo it looks like i got the motor to run. But befor the motor starts to run it jumps into different directions and then its starts to run.
Any idea what this could be. I have changes the velocity and acceleration but nothing
Offline TPS
  •  2,627 2,627
Re: DQ542MA
« Reply #15 on: February 11, 2019, 11:41:12 AM »
do you only plug the x-Motor (A/A- B/B-) to the y-axis Controller?
Re: DQ542MA
« Reply #16 on: February 11, 2019, 11:46:47 AM »
I have tried that and also with all the wires transferred to other driver
Offline TPS
  •  2,627 2,627
Re: DQ542MA
« Reply #17 on: February 11, 2019, 11:51:56 AM »
how are the dip Switches set on the HY-Div 268N ?
Re: DQ542MA
« Reply #18 on: February 11, 2019, 12:09:57 PM »
1Off
2On
3On
4Off
5On
6Off
Offline TPS
  •  2,627 2,627
Re: DQ542MA
« Reply #19 on: February 11, 2019, 12:20:38 PM »
if i have a look to the Manual:
1Off
2On
3On
means 0,6A Motorcurrent
4Off
5On
6Off
means 1/8 step ,if you have a stepper Motor with 400 imp/rev -> 3200 imp/rev
according to this https://wiki.kreitek.org/_media/proyectos:cnc:div268n-5a-datasheet.pdf manual
your posted DQ542MA setttings where:
1 Off
2 On
3 Off
means Motor current 3,31A
5 Off
6 Off
7 On
8 On
means 1600 pulses/rev
according to this: https://www.hobbytronics.co.za/Content/external/472/DQ542MA%20English%20Manual.pdf  Manual
so something does not match
« Last Edit: February 11, 2019, 12:22:40 PM by TPS »
