Hello Guest it is November 07, 2026, 02:33:31 AM
Author Topic: Configuring Keys In Key Board Inputs Configuration Table  (Read 30879 times)
Re: Configuring Keys In Key Board Inputs Configuration Table
« Reply #20 on: March 24, 2019, 11:45:32 AM »
I think the jog functions need an axis.  So when you get and set the jog rate you need to set it for each axis.   I ran into this problem about a month ago.
Mc.jog (inst, Axis#, jog rate)
I can't double-check this right now, I'm not at home, but I think that is what it is looking for.  You will need 3 lines to set it for X, Y, and Z.
Chad Byrd
« Reply #21 on: March 24, 2019, 11:54:09 AM »
Like this:?
-Set Jog Rate
function Feed2()
    local Feed2 = mc.mcJogGetRate(inst)
   mc.mcJogSetRate(inst, 0, JogRate)  --Motor 0
   mc.mcJogSetRate(inst, 1, JogRate)  --Motor 1
   mc.mcJogSetRate(inst, 2, JogRate)  --Motor 2
   mc.mcJogSetRate(inst, 3, JogRate)  --Motor 3
    if Feed2 == 100 then
       mc.mcCntlSetLastError(inst, "Can't increase JogRate anymore.")
    else
       local Feed2 = (Feed2 + 10)
       mc.mcJogSetRate(inst, Feed2)
    end
end
« Reply #22 on: March 24, 2019, 11:55:20 AM »
Ok, tried it, don't work.  rats and more rats
« Reply #23 on: March 24, 2019, 12:23:55 PM »
I tried this, no work either   :-[
--Set Jog Rate
function Feed2()
    else
      mc.mcJogSetRate(inst, mc.X_AXIS, SetRate) -- set set for axis
      mc.mcJogSetRate(inst, mc.Y_AXIS, SetRate) -- set set for axis
      mc.mcJogSetRate(inst, mc.Z_AXIS, SetRate) -- set set for axisMotor 3
    end
end
« Reply #24 on: March 24, 2019, 02:12:11 PM »
Once I get home to my laptop I will proof some code out and post it.
Chad Byrd
« Reply #25 on: March 24, 2019, 04:01:22 PM »
Ok, Great, can't wait to see what you come up with.  Thank you.
« Reply #26 on: March 24, 2019, 05:30:13 PM »
Here is what I came up with; I made two buttons and put the code in the Clicked Script inside the button, you can make it a function if you like, but these work to increase and decrease the jog rate by 10%.  You can change that to whatever you like, or add another button to change the resolution of change.
--Jog Rate +10%
local CurrentRate = mc.mcJogGetRate(inst, 1)
local JogRate = (CurrentRate + 10)
if JogRate <= 100 then
else if JogRate > 100 then
    mc.mcCntlSetLastError(inst, "Can't set Jog Rate higher")
end
end
--Jog Rate -10%
local JogRate = (CurrentRate - 10)
if JogRate >= 10 then
else if JogRate < 10 then
    mc.mcCntlSetLastError(inst, "Can't set Jog Rate Lower")
end
end
Also,
There is a little glitch; this occurred to someone else, I just remembered that they mentioned it happens so be aware of it.
It won't display correctly when you lower it below 50% unless you first change it to 0% and then you can freely raise and lower it from 0-100%.
I don't know why, that's the way it is.  So, when you start, just manually change the jog rate to 0% and you'll be good to go.
Also, looking at your code, maybe change the Axis to an integer instead of writing out the axis, your code may work just fine.
« Last Edit: March 24, 2019, 05:31:50 PM by Cbyrdtopper »
Chad Byrd
« Reply #27 on: March 24, 2019, 05:59:46 PM »
Well thank you, i'm going to do some plug and play to see how it works.   Let you know soon.......and thank you again for all your time on this.
Fritz
« Reply #28 on: March 25, 2019, 01:55:56 PM »
Hi,  Well, I didn't get your scripts to work, but I did figure it out using your parts, thanks to you!!   I got this working well in windows 7pro and 10pro.  The only thing is can't use the mouse on the slider or it will disrupt the DRO for some reason, but I don't use a mouse anyhow on any CNC machinery, I have touch screens.   Here is what I'm using and so grateful because of you.
Offline smav
  •  56 56
« Reply #29 on: January 06, 2020, 10:10:16 PM »
Chad--I had the same issue with DRO not wanting to accurately record the jog rate when I used my pendant. I found that what it was doing was it would count down to what ever the initial value was set at when I started up mach4 and then count no lower. What I did to curb that issue was to set it to default to the value of 1 at start up so after I start march4 up I can use the mouse with slider,my pendant or keyboard interchangeably with no issues, the DRO value always tracks on as it should.
