G-Code, CAD, and CAM > G-Code, CAD, and CAM discussions
G-Code bad character used
jbaumchen:
Thanks all for your help. I think I'll try the PCB-Gcode as it seems the most logical choice. Cheers!
joeaverage:
http://eagle.autodesk.com/eagle/ulp?utf8=%E2%9C%93&q%5Btitle_or_author_or_description_cont%5D=pcb-gcode&button=
As I recall I downloaded and extracted to a folder in MyDownloads. I seem to recall it was necessary to inform Eagle of the path to
that folder.
To generate Gcode at the Eagle command line type 'run pcb-gcode'<enter>.
To enter the setup type 'run pcb-gcode-setup'<enter>.
joeaverage:
with Eagle open Options/Directories and update the path to the pcg-gcode folder.
jbaumchen:
Hey Craig,
I noted that the PCB-Gcode for Eagle was tested on Version 5.1. I'm using Eagle 9.3 and installed the PCB-Gcode files in my Eagle directory. It always opens the configuration app but doesn't give a list of gcode programs to select from. I've tried finding Eagle V5.1 but the earliest version I can find for download is Eagle 6.6. If PCD-Gcode is supposed to work with V9.3, do you happen to have a link for it?
joeaverage:
I have Eagle 6.6 and it works. I have heard that it works with Eagle 7 also but I can't personally confirm that.
Note there is an active pcb-gcode forum (Google Groups), if you are starting out with pcb-gcode it is recommended.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
