Hello Guest it is October 20, 2026, 11:02:07 PM
Author Topic: Wait for signal  (Read 95285 times)
Re: Wait for signal
« Reply #20 on: January 25, 2019, 01:21:33 PM »
G21 G40 G54
G80 G90 G94
G00 X7.841 Y78.301
G00 Z0
G01 F60 Z-3
G00 Z2
G00 Y73.45
G00 Z0
G01 F60 Z-3
G00 Z2
M47
Re: Wait for signal
« Reply #21 on: January 25, 2019, 01:22:36 PM »
so ii want for example to wait for signal at this position:
G00 X7.841 Y78.301
Re: Wait for signal
« Reply #22 on: January 25, 2019, 02:04:12 PM »
OK that's easy enough. What you need to do is insert a 'wait on signal' macro immediately after each
move that requires it.
That can be done as a macro. So open the script editor and open a new document but save it in your macros folder
of your current profile m199.mcs
This is the code:
Code: [Select]
function m199()
local inst=mc.mcGetInstance()
local rc=mc.mcSignalWait(inst,mc.ISIG_INPUT4,mc.WAIT_MODE_HIGH,10)
if (rc==mc.MERROR_TIMED_OUT) then
mc.mcCntlSetLastError(inst,'Timed Out')
return
end
end
if (mc.mcInEditor()==1)then
m199()
end
I have used this API (API.chm):
LUA Syntax:
rc = mc.mcSignalWait(
      number mInst,
      number sigId,
      number waitMode,
      number timeoutSecs);
Description:
Wait on a signal to change state.
Parameters: Parameter Description
mInst The controller instance.
sigId A valid signal ID. (NOT a signal handle)
waitMode An integer specifying whether to wait on the signal to go high (WAIT_MODE_HIGH) or low (WAIT_MODE_LOW).
timeoutSecs A double specifying a timeout period.
So in the code I have posted there is a 10 second TimedOut period while it waits for ISIG_INPUT4 to go high.
Re: Wait for signal
« Reply #23 on: January 25, 2019, 02:42:19 PM »
Thank you Craig. You are the best mate and thank you for the time you spent for me. I am going to study a bit about Lua when i recieve the book. Maybe one day i can be EXPERT like you!!!!
Re: Wait for signal
« Reply #24 on: January 25, 2019, 03:04:48 PM »
I am by no means an expert, scarely much more than a beginner.
I never bothered with the book, I just have the link open and delve into it at need.
