Hello Guest it is October 04, 2026, 01:03:23 AM
Author Topic: new screen an gcode m6 help  (Read 5512 times)
Offline gorf23
  •  190 190
« on: January 21, 2019, 10:26:36 AM »
I created a new screen and all seems to work fine.
but I am having a gcode problem the gcode runs fine till it gets a T6 M6, the code stops ok and I get the message to change to tool 5 and hit cycle start It say tool 5
so wrong tool number and when I hit cycle start I get the message do cycle start but never continues to run just stuck at the M6 line forever the same gcode and M6
macro works on the default screens so seems like there ok. problem is I get no errors so having trouble getting to the root of the problem..
anyone ever run into this and figured out the cause?
also when I shut mach4 down I cant reboot mach4 I get the message another instant of mach4 running
thanks gary
« Last Edit: January 21, 2019, 10:32:28 AM by gorf23 »
