Mach Discussion > Video P*r*o*b*i*n*g
Get Error when starting probing
(1/1)
grsabourin:
I'm using Mach3 under windows xp. I have issue when starting probing. In my case my probe is tool 250. I do tool change operation by doing T250 M6. The tool change mode is activated, I load the probe in the spindle and continue the operation and finally it confirm tool change completed. I start probing by probing the z height. It starts the operation but nothing move I get the following error : MT Mode Probe Op _MT not mounted. Probe Op Canceled.
Why this error is happening
Thank you
reuelt:
User solved his problem thru another forum
http://www.calypsoventures.com/forums/viewtopic.php?f=6&t=995
Navigation
[0] Message Index
Go to full version
