Hello Guest it is November 02, 2026, 04:03:36 AM
Author Topic: USB to PARALLEL WIN 7  (Read 23787 times)
« on: January 11, 2019, 10:02:18 AM »
Is it possible to use a usb to parallel cable converter on a K2 cnc with geckos.. Is there a special setup???
just in case I need to upgrade to a newer computer
« Last Edit: January 11, 2019, 10:13:51 AM by Cuemaker »
Re: USB to PARALLEL WIN 7
« Reply #1 on: January 11, 2019, 10:53:38 AM »
No.
But you can use a USB or ethernet motion controller instead of the parallel port.
Offline TPS
  •  2,627 2,627
« Reply #2 on: January 11, 2019, 02:16:19 PM »
just NO
Offline reuelt
  •  520 520
« Reply #3 on: February 26, 2019, 07:53:45 PM »
Perhaps low cost UC100 should do the trick.
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #4 on: February 26, 2019, 08:05:31 PM »
to call a UC100 a plain USB to parallel converter does the UC100 a grave injustice.
Inside the UC100 is an FPGA and it is a genuine, if IO limited, external motion controller and is way WAY WAY
more clever than a USB to parallel converter.
The only caution is that there are a ton of Chinese made UC100 look-a-likes on EBay and Amazon.
If you are going to buy, buy direct from CNCDrive or their nominated distributor. You don't want Chinese
rubbish, they aren't a patch on the genuine article.
