Hello Guest it is October 31, 2026, 08:12:11 AM
Author Topic: machinebed versus Mach3  (Read 68250 times)
Offline TPS
  •  2,627 2,627
Re: machinebed versus Mach3
« Reply #20 on: January 16, 2019, 09:05:26 AM »
can you please post a screenshot of
Config->Motor Tuning -> X-axis and
Config->Motor Tuning -> Y-axis
my pulley is a 20 teeth and the second wheel ? how many teeth?
« Reply #21 on: January 16, 2019, 10:10:54 AM »
1600 steps is 40 mm, so steps per unit is 40
« Reply #22 on: January 16, 2019, 10:24:56 AM »
@TPS request screenshot of
i used the Prusa calculator
https://www.prusaprinters.org/calculator/
« Last Edit: January 16, 2019, 10:31:26 AM by Thombus »
Offline TPS
  •  2,627 2,627
« Reply #23 on: January 16, 2019, 10:49:24 AM »
ok from motortuning X an Y should run the same Speed.
i would put 40 for acceleration.
a bit surprises me that step pulse and dir pulse is Zero, put 5 in there.
are you using parallel port or a Motion Controller ?
« Reply #24 on: January 16, 2019, 10:55:44 AM »
I do use A TC-50M as a controller.  No centronicsport but USB
step pulse and dir pulse where advised to be Zero, I will put 5 in there.
« Last Edit: January 16, 2019, 10:59:43 AM by Thombus »
Offline TPS
  •  2,627 2,627
« Reply #25 on: January 16, 2019, 12:32:25 PM »
ok had a look to the Manual, in this case i think 0 for step/dir pules is ok/does not matter.
back to the Basic Problem.
did you check the real distances as described (MDI G1Xsomething) and measure ?
same for Y axis.
anyway, if the real distances match to to the DRO's, X and Y should move the same Speed.
you can also do a simple test via MDI
G1X300Y300
should give a simulitanious move of both axis.
by rereading all the post's i recogiced that your machine is belt driven (my bad english,and the Age).
ok that means one motorrevolution is 40mm, right?
in this case your motortuning of velocity 400mm/min is very low (what actually means for the Motor 10 rev/Min).
don't realy know what Speed you expected to run?, but i think for a woodmill (have no Experience with Wood),
it is IMHO to slow.
