Hello Guest it is October 20, 2026, 03:08:46 PM
Author Topic: Yeah I know Im lazy  (Read 10815 times)
Yeah I know Im lazy
« on: August 09, 2007, 02:45:13 PM »
Im looking to gather the parts for a 9x20 lathe conversion. quite frankly I'm too lazt to build my own mounting hardware for the motors and Im going nuts finding anyone that makes a hardware kit for mounting some steppers to a lathe. I want to use a timing gear settup so I can gear things down a bit. i found one guy who advertises a kit. but sais he isnt making the kit right now. this is the link.
http://www.thompsonmachine.net/9x20kit.htm
anyone know of anyone making something similar to this. In the USA preferably.
Thanks anyway.
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Yeah I know Im lazy
« Reply #1 on: August 15, 2007, 01:32:29 PM »
I picked this up as I looked down the posts - what are you wanting - someone to do the job for you ??
Actually fitting the motors to my Warco lathe ( 5 ins throw steel turning with milling head) turned out easier than I thought.
I made a bracket to fix the motor to the lathe - a toothed belt drive (5mm pitch x 9mm wide). I used a 3 to 1 step down because i didn't need the speed, just the power. I did all three fittings in a day. Motors are 220 Ncm.
« Reply #2 on: August 15, 2007, 04:36:39 PM »
heh yah dont make me feel bad.
It's just Im going to add ball screws and I just didnt want to mess with machining the ends myself and messing with making a bracket with thrust bearings and all that jazz if I didnt have too. I figure I could just buy a X Y kit for a miny mill and adapt there brackets to suit my needs. but its not that Im lazy its just that I only have so much time and I have too many projects going at once. I just streamline where i can.
anyone got any recommendations on a bearing arrangement and even a good supplier for such an project. any guidence is apreciated as always
