Hello Guest it is October 11, 2026, 12:55:11 PM
Author Topic: New Mach 3 Won't load G code  (Read 25302 times)
Re: New Mach 3 Won't load G code
« Reply #10 on: January 10, 2019, 08:18:36 AM »
What is the file format you are trying to load? Have you tried moving your file onto your computer and running it from there? We don't recommend running g code from a USB drive.
-Bryanna
Newfangled Solutions Helpdesk: http://support.machsupport.com
YouTube Support Channel: https://www.youtube.com/c/MachSupportOfficial
« Reply #11 on: January 13, 2019, 04:00:38 PM »
I am trying old saved crv files I had saved on a flash drive and had created in Vectric cut 2d.  These are the ones that will not work.  The old xp computer that crashed had Mach 3 and Cut 2d on it.  I simply loaded directly to Mach.  Worked great until the crash.  Should I load V carve on the same PC as Mach?  I am planning in the future to build a cnc router and would prefer not to have to post process at each machine.
Since I lost cut 2d on the crashed computer I upgraded to V Carve Pro loaded on my new laptop.  Tried post processing file to Mach format onto a flash drive.  Options for Mach read:  Mach 2/3 Atc Arch (inch)(*.txt).  Will that work?
« Reply #12 on: January 13, 2019, 04:03:07 PM »
re-reading your reply do you mean save the crv file on my PC them load to Mach?
« Reply #13 on: January 13, 2019, 04:33:09 PM »
try renaming a file from *********x.crv to *********x.tap.
If I recall correctly there is a screen in Mach3 where you can set the acceptable/recognizable file extensions that
Mach expects.
Offline TPS
  •  2,627 2,627
« Reply #14 on: January 14, 2019, 01:23:12 AM »
can you post oene the .crv files witch does not work ?
« Reply #15 on: January 15, 2019, 08:01:37 AM »
CRV files aren't g code files. Make sure you're outputting your toolpath as a g code file (usually ends up being .txt) and not simply saving the project.
-Bryanna
