Hello Guest it is November 10, 2026, 01:56:50 AM
Author Topic: Y axis manual input  (Read 27256 times)
Y axis manual input
« on: January 01, 2019, 11:24:05 AM »
Hello
I'm trying to find a script that will allow me to manually input Y coordinates and then go to that position.  I dont want the MDI box, so I dont have to type "G0Y?" everytime
TIA
Offline TPS
  •  2,627 2,627
Re: Y axis manual input
« Reply #1 on: January 01, 2019, 11:29:03 AM »
load a GCode file.
for example
G0X10
G0X20
G0X30
G0X30
G0X40
enable Single BLK
than you only have to hit Start for every single line
« Reply #2 on: January 01, 2019, 11:32:55 AM »
Thanks, but not exactly what i am looking for.
What i want to do is: click on a button, enter a value: ie. 23.625, hit enter and have the machine go to that position
Offline TPS
  •  2,627 2,627
« Reply #3 on: January 01, 2019, 11:43:27 AM »
ok then something like this might help:
Code: [Select]
Sub Main
Dim YPos As String
YPos = AskTextQuestion("Please enter Y Position (use . not , !): ")
If IsNumeric(YPos) Then
Code "G0Y"+CStr(YPos)
Message "driving Y to: " & YPos
Else
MsgBox "Vaule you entered is not numeric!"
End If
End Sub
« Reply #4 on: January 01, 2019, 11:51:59 AM »
TPS, THANK YOU!!  that does exactly what I want...I am making a programmable stop for my cutoff say and this is going to work perfect....Thanks again!!
« Reply #5 on: January 01, 2019, 01:47:31 PM »
Can I ask 2 more questions, If I enter a value over 50 for Y, how can I have a message box say "value too high"  And I have a virtual num pad that appears when the F9 key is pressed, is there a way to wmulate the F9 in a script so that the keypad comes up automatically
Offline TPS
  •  2,627 2,627
« Reply #6 on: January 02, 2019, 02:07:33 PM »
ok sorry for the delay,
first question no Problem, new code:
Code: [Select]
Sub Main
'declare variables
Dim YPos As String
Dim YMinPos As Double
Dim YMaxPos As Double
'preset the variables
YMinPos = 1.0
YMaxPos = 50.0
'show the input Box
'check that the entered value is numeric
 'check the minimal value
 If CDbl(YPos) < YMinPos Then
    MsgBox ("entered value too low !")
    Exit Sub
 End If
 'check the maximal value
 If CDbl(YPos) > YMaxPos Then
    MsgBox ("entered value too high !")
    Exit Sub
 End If
Else
End If
End Sub
second question:
here i am not sure what would be the Trigger for "comming up" of the Keyboard (maybe the script, witch asks for the YPos?),
and how to trigge the Keyboard?
TPS
BTW:witch virtual Keyboard do you use? maybe i can choose a copy and test?
« Last Edit: January 02, 2019, 02:15:49 PM by TPS »
« Reply #7 on: January 02, 2019, 05:11:37 PM »
Thanks again!!  I got the keyboard figured out
« Reply #8 on: January 02, 2019, 05:56:15 PM »
TPS
is there any way to duplicate the user input into a DRO?
Offline TPS
  •  2,627 2,627
« Reply #9 on: January 03, 2019, 12:44:24 PM »
hi,
here is a code sample witch uses DRO for strorage (to Display).
it uses a selfmade virtual Keyboard for numeric Input via touch Screen.
all values (min max DRONum) are adjustable in top aeria.
Code: [Select]
Global value As String
Sub Main
'declare variables
Dim YPos As Double
Dim OldDroValue As Double
Dim DroNum  As Integer
YMinPos = 1.0
YMaxPos = 50.0
DroNum  = 1201
'get the actual DRO value
OldDroValue = GetOemDro(DroNum)
'show the virtual keyboard
call NumericKeyboard(DroNum,YMinPos,YMaxPos)
'get the new DRO value
YPos = GetOEMDro(DroNum)
'check that the entered value has changed
If YPos <> OldDroValue Then
'doe the move
End If
End Sub
'TPS 01.12.2017
'numerische Eingabe
Function NumericKeyboard(ByVal DRONum as Integer , ByVal Min as Double , ByVal Max as Double) As Double
Dim title as String
value = "" 'GetOemDRO(DRONum)
title = Header
Begin Dialog UserDialog1 60,60, 105, 210, "input value:"  , .Enable
PushButton 10, 10, 25, 25, "7", .but7
PushButton 40, 10, 25, 25, "8", .but8
PushButton 70, 10, 25, 25, "9", .but9
PushButton 10, 40, 25, 25, "4", .but4
PushButton 40, 40, 25, 25, "5", .but5
PushButton 70, 40, 25, 25, "6", .but6
PushButton 10, 70, 25, 25, "1", .but1
PushButton 40, 70, 25, 25, "2", .but2
PushButton 70, 70, 25, 25, "3", .but3
PushButton 10, 100, 25, 25, ".", .butD
PushButton 40, 100, 25, 25, "0", .but0
PushButton 70, 100, 25, 25, "<-", .butB
PushButton 10, 130, 25, 25, "+/-", .butN
PushButton 40, 130, 25, 25, "Del", .butDel
TextBox 10, 160, 85, 18, .FText
PushButton 10, 185, 40, 21,"OK", .OK
CancelButton 55, 185, 40, 21
End Dialog
Dim Dlg1 As UserDialog1
Dlg1.FText = CStr(value)
x = Dialog( Dlg1 )
NumericKeyboard = CDbl(Dlg1.FText)
If CDbl(Dlg1.FText) < Min Then NumericKeyboard = Min
If CDbl(Dlg1.FText) > Max Then NumericKeyboard = Max
SetOEMDro(DRONum,NumericKeyboard)
End Function
Function Enable( ControlID$, Action%, SuppValue%)
Select Case Action%
Case 1
Case 2 'Button wurde gerückt
If ControlID$ = "but0" Then
value = CStr(value) + "0"
DlgText "FText", CStr(value)
Enable =1
End If
If ControlID$ = "but1" Then
value = CStr(value) + "1"
Enable =1
End If
If ControlID$ = "but2" Then
value = CStr(value) + "2"
Enable =1
End If
If ControlID$ = "but3" Then
value = CStr(value) + "3"
Enable =1
End If
If ControlID$ = "but4" Then
value = CStr(value) + "4"
Enable =1
End If
If ControlID$ = "but5" Then
value = CStr(value) + "5"
Enable =1
End If
If ControlID$ = "but6" Then
value = CStr(value) + "6"
Enable =1
End If
If ControlID$ = "but7" Then
value = CStr(value) + "7"
Enable =1
End If
If ControlID$ = "but8" Then
value = CStr(value) + "8"
Enable =1
End If
If ControlID$ = "but9" Then
value = CStr(value) + "9"
Enable =1
End If
If ControlID$ = "butD" Then
   If InStr(1,value,".") = 0 Then
value = CStr(value) + "."
Enable =1
   End If
End If
If ControlID$ = "butB" Then
value = Left(value,Len(value)-1)
Enable =1
End If
If ControlID$ = "butN" Then
If Left(value,1) = "-" Then
value = "+" + CStr(Right(value,Len(value)-1))
Else
If Left(value,1) = "+" Then
value = "-" + CStr(Right(value,Len(value)-1))
Else
value = "-" + CStr(value)
End If
End If
Enable =1
End If
If ControlID$ = "butDel" Then
value = ""
Enable =1
End If
If ControlID$ = "OK" Then
Enable = -1
End If
Case 3 'Text verändert
'MsgBox Dlg1.FText
Case Else
End Select
'Wert zurückgeben
If Enable = -1 Then
Enable = value
End If
End Function
