Third party software and hardware support forums. > PoKeys
VFD RPM control wiht Pokey57CNC 1-10V output does not propperly work
exflueger:
Now I also did a test by directly 'infusing' 0-12V from my Lab power supply into the Inverter to VI and DCM.
Works also like a charm.
TPS:
ok sounds like you have all 'basic' tests allready done.
maybe you can give me some more detailed Information about your wiring,
just to confirm. (ok i know that is "i know every better mode")
all that sounds like a grounding (0V) Problem.
TPS
exflueger:
If somebody has the same problem, here the solution:
I did several experiments meanwhile and also went back to the idea that the Inverter infuses to much noise down the lines. So I tried the Ferritering again. But this time with two really big Ferrite Tubes and a large amount of windings and put them separate to both lines, one per line (Vi and iGND). And I added a Capacitor with 10uF between Vi and iGND.
It became much better. Not perfect but much better. So this was the right trace to follow.
So I did the XXL hard core version of it (see Pic's).
Two really big ferrites, lots of windings and, very important: a 0.022uF Capacitor between iGND and 0-10V output.
With all this it now works 100% OK
Thank you TPS for the coaching!
rodm717:
Nice! I see you are also using the postep60-256 drivers as well. might wannt to tie those twisted lines off before your fan eats em' ;)
exflueger:
Hi
This was just the test-setup. Now all is nicely fixed, no food for the Fan. :-)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
