Hello Guest it is November 22, 2026, 08:14:52 AM
Author Topic: bitsensor usb controller  (Read 27943 times)
Offline comet
  •  338 338
« on: December 12, 2018, 12:30:15 PM »
Hi just bought one of these off ebay, everything on the CD is in Chinese, can anyone point me to an english manual or set up instructions? ive got as far as loading the plugin and it isnt throwing up any errors. ive connected it within mach3 and the plugin control is there so im assuming so far so good. however not sure how to set up the ports? ive set up uc300's and smooth steppers so im not a novice!!
Regards
  Tony
Re: bitsensor usb controller
« Reply #1 on: December 20, 2018, 11:41:45 AM »
I see you've had no replies....it doesn't surprise me I don't know that anyone has been able to get these junk boards to work.
Do yourself a favour and get another SmoothStepper or UC300, as you know....they work as intended unlike Chinese rubbish.
Offline TPS
  •  2,627 2,627
« Reply #2 on: December 21, 2018, 01:55:42 AM »
Offline comet
  •  338 338
« Reply #3 on: December 21, 2018, 05:27:34 AM »
Hey Craig thanks for that really helpful advice ,that was exactly what I was looking for!
Actually I worked it out myself, you just have to use the correct plugin,works a treat  had one running 4 axis on a soak test for 48 hours not one problem. fantastic value at £20 a pop as opposed to £140 for a uc300 or£200 for a smooth stepper,
 just ordered another 4 as they cant be at that price for much longer !
    Merry Christmas
  •  9,378 9,378
« Reply #4 on: December 21, 2018, 05:54:56 AM »
« Reply #5 on: December 21, 2018, 12:26:15 PM »
kool. post how you did it.....there are dozens of people out there who have this board and can't get them to work,
they would appreciate your help.
Offline comet
  •  338 338
« Reply #6 on: December 22, 2018, 07:10:35 AM »
having trouble up loading the RnR motion dll plugin file ive even tried changing it to .dxf for upload???
« Reply #7 on: December 22, 2018, 10:52:24 AM »
there are a limited number of file formats which can be attached. Also each file attached must have a unique name, so if someone loaded a file
of the same name three years ago.......It may be appropriate to lodge the file on the net somewhere and then link to it.
Its may well be the instructions of how you got it to work rather than the .dll file would be more valuable to others.
Just as a matter of interest now that you have got the board to work have you tried G31 probing?
Offline TPS
  •  2,627 2,627
« Reply #8 on: December 24, 2018, 03:55:48 AM »
try to ZIP it
Offline comet
  •  338 338
« Reply #9 on: December 24, 2018, 03:57:24 AM »
try this:
