Hello Guest it is November 02, 2026, 08:47:52 AM
Author Topic: X axis moves only left, with both + and - inputs  (Read 19612 times)
« on: November 23, 2018, 01:37:37 PM »
Using Win7 and Mach3 version R3.043.066
Problem: stated in subject line
All was working last year, but have not used it since then
  •  9,375 9,375
Re: X axis moves only left, with both + and - inputs
« Reply #1 on: November 24, 2018, 12:45:38 AM »
Check your wiring.
In particular the X axis Direction pin connection.
If you are using the Parallel Port then check your 25 way cable itself.
Also check the wiring and connections to the X axis motor (check both windings are connected).
« Reply #2 on: November 24, 2018, 05:32:39 PM »
Thanks for your reply.
I have checked the  Dir connections, and all are OK.
Steppers are NEMA 12v 2 phase 1.8 ° 4 lead    Resistance/Phase 1.5 ohm
Checked, with an ohmmeter, the the readings, at the X motor, are:   A - 2.0, B - 2.2
   Y motors A - 1.4, B - 1.6   Z motors A - 1.6. B = 1.4
I will check further, when I have time, and let you know what I find
Don
