Hello Guest it is October 23, 2026, 07:47:35 PM
Author Topic: How to use OEM301  (Read 12526 times)
How to use OEM301
« on: November 13, 2018, 07:54:39 AM »
How to use OEM301
Which macro file is OEM301?
Re: How to use OEM301
« Reply #1 on: November 13, 2018, 08:10:50 AM »
You will find some info on OEM code 301 in the Mach3 Macro Programmers Reference manual.
I have never used it.
Offline rcaffin
  •  1,073 1,073
« Reply #2 on: November 15, 2018, 03:08:32 AM »
I suspect the only person who has ever used OEM301 was Art Fenerty, and also that he used it just once for some special task.
My 2c.
Roger
« Reply #3 on: November 15, 2018, 05:32:12 AM »
Looks like the Wiki is now gone, so can't look it up.
Is OEM301 used for OEM triggers, like I think?
If so, it's not terribly useful, as it only works with one input.
  •  9,374 9,374
« Reply #4 on: November 15, 2018, 06:52:21 AM »
Sorry guys, a bit off-topic but it is devastating that the Wiki has gone  :'(   so much information from the past just wiped out ???
Offline rcaffin
  •  1,073 1,073
« Reply #5 on: November 15, 2018, 03:31:48 PM »
From Ref Manual:
Sub SetTriggerMacro(MacroNum As Integer)
This function allows an M-macro to be associated with OEM code 301. This can be used
to cause one of the OEM Trigger signals to automatically run a macro when asserted. To
do this, the OEM Trigger signal must first be configured in Config->Ports&Pins-
>InputSignals. Then the OEM Trigger must be associated with OEM code 301 in
Config->SystemHotKeys. Finally, SetTriggerMacro must be used to define which Mmacro
will be executed when OEM button code 301 is executed.
Arguments:
MacroNum is the number of the M-macro to be run when OEM button code 301
is executed.
Return Value:
None
Example:
‘ Assume OEMTRIGGER5 is assigned to OEM code 301
‘ Assign the M1025 macro to OEM Code 301
SetTriggerMacro(1025)
‘ Now, when OEMTRIGGER5 is driven to its active level,
M1025.m1s will be executed
Simple, ennit?
Roger
