Hello Guest it is October 26, 2026, 04:03:34 PM
Author Topic: Problem generating 3+2 G code  (Read 216528 times)
« on: November 10, 2018, 04:54:26 AM »
     I am experiencing problems generating 3+2 axis (5 axis positional ) G code to run on Mach3,
     Any ideas would be most hepfull
  •  9,374 9,374
Re: Problem generating 3+2 G code
« Reply #1 on: November 10, 2018, 05:11:52 AM »
If you Google 5 Axis CAD/CAM software you should find a choice of suitable programs.
Not one of my favourites but there are many here who like BobCAD-CAM and that will generate 5 axis toolpaths suitable for use with Mach3.
« Reply #2 on: November 10, 2018, 05:27:43 AM »
Currently using Fusion 360 for modelling,
And posting out G code,
Thanks for quick response
« Reply #3 on: November 10, 2018, 05:51:12 AM »
It's helpful if you describe what the problems are that you are having.
« Reply #4 on: November 10, 2018, 06:18:57 AM »
On posting code Mach 3 states that its unrecognizable and does not run
« Reply #5 on: November 10, 2018, 06:43:59 AM »
Are you using a Mach3 post processor in Fusion360?
« Reply #6 on: November 10, 2018, 07:16:47 AM »
No, I am trying to use Fusion 360 listed post processor,
When I tried Mach 3 post processor it flagged up "tool path orientation not supported",
« Reply #7 on: November 10, 2018, 07:33:57 AM »
Then it sounds like you need a new post processor.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #8 on: January 24, 2019, 06:38:25 PM »
Are you using the free version of Fusion, from memory its not 5 axis only the Pro version is.
Offline Stuart
  •  311 311
« Reply #9 on: March 26, 2019, 09:19:08 AM »
There is only one version now
The dif between free and pay is you only get generative design if you stump up else it’s the same
