Hello Guest it is September 17, 2026, 02:22:08 PM
Author Topic: Z axis design and Mach3 control  (Read 27856 times)
Re: Z axis design and Mach3 control
« Reply #10 on: October 17, 2007, 01:53:29 PM »
Steps per is irrevelant.
I'm talking about the display in the DRO.  It vascillates around between 358.4 or so, and 0.9 degrees.  Around a circle or square it goes fro 0.00 degrees to 0.9 degrees or so.
It should do the full 360 degrees - NO?  How far the motor actually moves is a number setting.  Right now, it is set at 50 SPI or 18000/360.
« Reply #11 on: October 17, 2007, 02:34:13 PM »
No, steps per are very important.
Offline Whacko
  •  239 239
  • Happy Days
« Reply #12 on: October 17, 2007, 03:13:23 PM »
Can you post a typical gcode file that you use?
Whacko
Nothing's impossible
« Reply #13 on: October 17, 2007, 04:20:25 PM »
Also, is the rotary axis set to angular in general config? Also in Genreal config, you can allow for 360 rollover. Do you have soft limits set for the rot. axis?
« Reply #14 on: October 17, 2007, 04:21:26 PM »
It's a simple square with filleted corners and a few holes.
Nothing fancy.
