Hello Guest it is October 22, 2026, 07:11:53 PM
Author Topic: Jogging  (Read 22883 times)
compunerdy
Jogging
« on: March 27, 2006, 01:46:44 AM »
For some reason I cannot get my motors to jog except with Jog INC on. When jog INC is on I can make the motors move incremental or I can fast move them using ********* + arrow key. But, with jog INC off and regular jog on I cant get them to move with or without holding the shift key down. Any thoughts?
Tim
Re: Jogging
« Reply #1 on: March 27, 2006, 05:56:56 AM »
Press the "Tab" key and check you slow jog %
www.newfangledsolutions.com
www.machsupport.com
compunerdy
Re: Jogging
« Reply #2 on: March 27, 2006, 09:34:49 AM »
Thanks for showing me that handy screen.  ;)
Still no luck though. I tried changing slow jog% to 0,25,50,75, and 100 and still could not get it to work.
Tim
Re: Jogging
« Reply #3 on: March 27, 2006, 06:08:47 PM »
Is Jog mode on? it should be on the screen at the bottom.
Please post your XML if you could :)
www.machsupport.com
compunerdy
Re: Jogging
« Reply #4 on: March 27, 2006, 06:56:40 PM »
Yes..jog's green led is on. moving the arrows does nothing.
turn jog inc on also and I can press the arrow and it will move the set distance or I can press shift+arrow and it will move really fast.
with just jog on I cant get it to do anything.
I am new to this..which xml file?
Re: Jogging
« Reply #5 on: March 27, 2006, 08:20:16 PM »
Can you please check you jog mode? I think you may be in MPG mode :)
www.machsupport.com
compunerdy
Re: Jogging
« Reply #6 on: March 27, 2006, 08:45:34 PM »
That was it!!!! Thanks
I have to say watching them motors move is just way too cool :D
Re: Jogging
« Reply #7 on: August 23, 2010, 07:46:42 PM »
I'm running Mach3 and I can't get my machine to jog. The jog toggle is turned on. I checked and I'm not in MPG mode. The DRO says the motors are moving but they aren't. This machine is new. I'm running Windows Vista operating system. Can you help please?
Re: Jogging
« Reply #8 on: August 23, 2010, 07:54:26 PM »
If the DRO is working then the motors should be moving. Typically this is a result of incorrect port and/or pin settings.
