Hello Guest it is November 13, 2026, 09:28:49 PM
Author Topic: CSS in mach3  (Read 6590 times)
CSS in mach3
« on: October 06, 2018, 05:38:00 AM »
Hi guys
I've been using mach3 for almost a year now. I am satisfied with all the equipment, but I have always had the problem of trying to solve it with the help of a forum, but for now I have not found any solution.
When I want to use turning with constant cutting speed, the rotations are changing successfully according to the diameter of the machining.
The problem is in feeds. The more the tool goes towards the centers, lower are feeds in mm/rev.
I also realize that when the first operation is finished the second operation will starts somethimes with more faster feeds as they are commanded.
Does anyone have a solution?
