Hello Guest it is November 22, 2026, 02:25:56 PM
Author Topic: LCam & revolving line  (Read 9443 times)
« on: July 31, 2007, 11:35:31 AM »
Hi to all,
I want to use my mill and rotary axis in a lathe mode. So far I assigned rotary axis as a spindle and put it on vertical position. I don't know how to generate that revolving line to obtain a round piece. It is possible to do that in LCam? If so how can I do that? I try to import a line (generated in Rhino)in LCam but I failed. Any advice will be very appreciated.
Thank you
Balsanu Gabi
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LCam & revolving line
« Reply #1 on: July 31, 2007, 05:58:46 PM »
Hi, Balsanu Gabi
Ii loaded your file its a 3D file, Make a simple 2D drawing and use LCam to set depth of cut and offset / pocket features.
It loads as is, Just takes a while and not usable, Its still crunching even though it says Not Responding, Most of the Time.
Thanks, Chip
