Hello Guest it is November 03, 2026, 01:17:39 AM
Author Topic: Wanting to update my version of mach 3 to newer release  (Read 7678 times)
Offline Jackal
  •  173 173
« on: September 08, 2018, 09:02:48 PM »
Hello,
I haven't  been on here in a while.
When I did my retro back  in  2011, Hood gave me a lot of help.
 I want to update to a newer version.
 Can you tell me what I need to look at and save in my current settings?
 I don't  want to update  and lose my current tuning and parameters.
Jack
Everything is bio-degradable if you run over it enough with a lawnmower.
  •  9,375 9,375
Re: Wanting to update my version of mach 3 to newer release
« Reply #1 on: September 09, 2018, 01:25:55 AM »
Make a secure backup copy of your existing Mach3 folder.
Install version R3.043.062 over the top of your old version. http://www.machsupport.com/software/downloads-updates/
Your existing settings should all be preserved.
If, for some reason they are not then you need to copy across from your backup your <profile> .xml file.
In addition, you may possibly need to copy across any special screen .set files (and their associated bitmap folders) together with any Brains, Macro's and Plugins that you may have been using (just copy the relevant folder from the backup to the new install).
Offline Jackal
  •  173 173
« Reply #2 on: September 09, 2018, 03:26:28 AM »
Thanks Tweakie!!
I'll  download  and get started!!
Will let you know how it goes.
